DBearss Posted October 27, 2016 Share Posted October 27, 2016 Like the attached is there a way to manipulate a rectangle one? I searched and found no real results so am thinking it is something simple. Link to comment Share on other sites More sharing options...
chief58 Posted October 27, 2016 Share Posted October 27, 2016 David what if you used a window and match roof then put in the amount of mutin's you need horizontial just a thought if it works you can adjust it Link to comment Share on other sites More sharing options...
DBearss Posted October 27, 2016 Author Share Posted October 27, 2016 Ray, The lites are disabled when you change the window shape to a triangle. Link to comment Share on other sites More sharing options...
jcaffee Posted October 27, 2016 Share Posted October 27, 2016 use a Louvered window type. Link to comment Share on other sites More sharing options...
DBearss Posted October 27, 2016 Author Share Posted October 27, 2016 Jon, Same scenario. as the louvers only work where the window frame is vertical. Link to comment Share on other sites More sharing options...
jcaffee Posted October 28, 2016 Share Posted October 28, 2016 Give this a go. Manual Louvers JCC_Louvers.plan 1 Link to comment Share on other sites More sharing options...
DBearss Posted October 28, 2016 Author Share Posted October 28, 2016 That'l work. Thanks Jon. Link to comment Share on other sites More sharing options...
