OldCKD Posted October 27, 2016 Share Posted October 27, 2016 I just went to do a quick ray-trace on a project I am finalizing, and got a bit of a shock at how one object rendered. The object was imported from Sketch-Up, and looked just fine in the camera view. But after the rendering developed - surprise! Any way to fix this? Why did this happen? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 27, 2016 Share Posted October 27, 2016 It's probably a missing texture. Sometimes the models imported from Sketchup just have a pic of the front of the fixture. If it isn't properly imported into the Library Chief can substitute what if thinks is "close". Link to comment Share on other sites More sharing options...
OldCKD Posted October 27, 2016 Author Share Posted October 27, 2016 Thanks Joe. I think you're right about the pic - looking at my camera view, it appears it's a little skewed on the face of the object. I needed a Bertazzoni range and thought I'd found an adequate one but this isn't working. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 27, 2016 Share Posted October 27, 2016 That's a bummer! Unfortunately there are a lot of poorly done models in the 3D Warehouse. Many are just cube shapes with a pic applied to each face. That's not the same as a detailed model with different materials. Link to comment Share on other sites More sharing options...
jcaffee Posted October 27, 2016 Share Posted October 27, 2016 Try... http://www.modelplusmodel.com/tech/appliances/1013-bertazzoni-range.html You may have model compatibility issues with their *.obj. If you go this route and have trouble with the obj model, then give a shout and I can run it through a MooTools conversion to 3ds, dae, or skp with all the correct material areas. Link to comment Share on other sites More sharing options...
