Landing Height Not Accurate in Elevation
Anna_Gorres
Hello,
Plan is attached. This is a simple plan for a permit. I entered the top of landing height in it's specifications box to be 11'-6". When I measure the elevation, it is way off (South Elevation).
This inaccuracy is what makes me worried about using Chief. What is causing this?
Thank you!
Anna
Hello,
Thank you!
Anna
Anna,
If you are using X8 (good to let everyone know which version) check to see which 'Elevation Reference' the 11' - 6" is being measured from - floor; finished floor; terrain; etc. If the landing is outside a room it will ignore the interior floor heights or interpret them badly, try using terrain as the 'Elevation Reference'.
