Rotate only part of a plan
mslewis620
Far into my existing floor plan - just found out that one dimension on the survey is off nearly 4.5'. The family room end of the house was an addition that has odd angles. I finally called the surveyor after measuring the house 3 times.
I need to manipulate about 25% of the first floor and change the angle as well to make it work out.
Any recommendations on the easiest way to accomplish this or should I just delete that area and start over. Every room in this house is at a different elevation with varying ceiling heights so I hate to go backward.
