Snags with Landings and Rooflines
I am using Home Designer Suite and have a couple questions/ problems and have attached a sample plan to illustrate.
1. Can you place furniture on a stair landing without adjusting the Floor to Bottom value? In the sample image, item 1 shows two chairs placed "on" a landing. However, chair "a" was raised using the Floor to Bottom value and "b" was not. Another problem is as soon as I place the chairs they "disappear" beneath the landing! Even when I raised chair "a" to be above the landing, in the plan view it is still hidden! The only way I can see it was to make the Landing fill semi-transparent. It is like there is no way to "bring the chair to the front" so it is first selected (unless I haven't found this feature yet)?
2. This stair goes to the second level and although I have no ceiling above the landing, there is a solid wall (item "c") that I don't want there (the "x" area should be gone so you can see down to the landing below). If I make the wall invisible, then the exterior wall to the roof line above disappears (since it is the same wall... this is understandable). But how can I get rid of area "c" so I can view the landing from the second floor?
If anyone can help, I would really appreciate it! Thanks.
SamplePlan.plan
Question #1  Make your landing the Back Group.  And yes I believe that any item placed on stairs or landings will need a manually entered elevation.
Question #2 Not sure I understand exactly which wall you mean as your description does not seem to be the same as picture.
C is an exterior wall in your sample plan and does not appear to block the view of the landing from above? You can alter a wall from it's default height by shortening it in a 3D view or the stair landing will terminate an interior wall that is under it.  Other than that I am not sure what you are after exactly.
Also Home Designer Questions are normally posted in the Home Talk Forum.
Thanks for the reply. I tried moving the chairs to the front of the group but they are still hidden behind the landing. I am disappointed that objects placed on a landing are by default instead placed on the floor underneath the landing. This makes no sense and should be reversed in my opinion.
As for the second item. Sorry if I didn't make it clear, but the area "c" with the X on it shouldn't be there. I've attached another screen shot showing how the area with the X i want cut away (by making that wall invisible), but as you can see it also makes the exterior part invisible and messes up the area along the roof line outside. Does that make more sense?
Also, I'll post in the other section when I have future questions. Thanks for the heads up.
    29495
    ChiefRosieRue
    ChiefRosieRue
  • Similar Content
    • By JamesKCI
      Hey All,
      My company is in the process of making the switch from Autodesk Revit to Chief Arch (Version X12) and I have been spending my time trying to create a lot of commonly used design elements we use on our plans but I have run into a hiccup. I'm trying to create a small, inset-type staircase (attached image is what I've done in Revit in the past) that is typically used on our plans to go from grade-level sidewalk to the main floor elevation. In my attempts, stairs either fail to recognize the elements around them or if I create them like I would in Revit in creates this garbled configuration where the stairs are their own room and the footprint of the stairs themselves cut a hole through the roof.
      Checking Forums, YouTube, and the Chief site have all yielded nothing and I in my limited knowledge cannot figure it out. What am I missing?
    • By No1ZZTopfan
      A bit of an issue. I have two staircases. One from the basement to the first floor. Directly above are the other stairs which go from the first to the second floor. When I run "Auto Stairwell" on the basement stairs, the other stairs drop to the basement. I have never had this issue in any other versions. Why? (See attached screen shoot). Running CA12 on Win10Pro.
      Thanks in advance.
    • By stevenyhof
      I'm making an electrical plan and trying to figure out how to add my electrical line to my light fixture over the stairs - shown on the main floor. So I have a 2 way switch at the bottom and top of the stairs.
    • By stevenyhof
      I was messing around with my template wanting to get some more things in place for my stairs and defaults. I ran into this before and just moved on, but now I am drawing homes using Chief and need to find a way to angle or follow the stairs with a halfwall. Thank you
      SND_D_Residential Template.plan
    • By Designer100
      1) Finished floor for this existing building is 36". The driveway in back is level with finish floor also. I cannot get the landscape all around to fill in under building and driveway. The drive slopes up to flat across as much as I have flat. The exist. H.C. ramp goes into a concrete porch. This is as-built plan and then I will design a restaurant on the first floor.
      2) I cannot get u shaped stairs to work and land on the 2nd floor by the entry door.
      I would appreciate any help in accomplishing what i need to do.
      Thanks,
      Newell
      Moheb Building.plan
