fliping floors
ChiefIBT
Go to solution Solved by DavidJPotter,
  • Solution
Yes but the process is as simple as it is unforgiving if you make a misstep. Read the section in the Reference Manual about flipping floors (changing floors and then experement using a simple test plan to make sure you fully understand the steps and get perfect test results before inflicting the procedure on your intended model.
