Slump Block Exterior Walls
Paul454
Hi,
Has anyone done a floor plan with 8" Slump Block exterior walls?  Would it be hard to modify the wall type to get the Slump Block look on the exterior?  Any help or suggestions will be greatly appreciated!
Thanks,
Paul
You can apply any material you want to a wall, first check the library and if there is nothing suitable you can get a photo and use it as a material for the wall and it can be edited in a photo editor to be seamless if you like.
