Christina_Girerd Posted September 24, 2016 Share Posted September 24, 2016 I'm working on an older home that has the equivalent of corner boards on it's bay windows. The cornerboard tool doesn't seem to work in this situation, so wondering if there are any suggestions aside from just using polyline solids? This bay window is angled, but I also tried the tool on a squared bay window just to see if it was the angle that was the difference - didn't work on those either, so I'm assuming the tool was only designed to work on regular wall corners. Sure would be handy if that tool did work in this situation as it is such a quick help on regular corners. Link to comment Share on other sites More sharing options...
Flymase Posted September 24, 2016 Share Posted September 24, 2016 Did you try the wall material region tool? I don't know if you have enough wall space to use this tool though. Link to comment Share on other sites More sharing options...
country Posted September 24, 2016 Share Posted September 24, 2016 The wall material region will not wrap properly around the corners. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted September 24, 2016 Author Share Posted September 24, 2016 Yes, I'm using the bay window tool. Thanks for the ideas. I ended up just using a polyline solid. Link to comment Share on other sites More sharing options...
jcaffee Posted September 24, 2016 Share Posted September 24, 2016 Use General Framing, then Join and Miter Ends tool. jon Link to comment Share on other sites More sharing options...
