Designer100 Posted August 30, 2016 Share Posted August 30, 2016 2nd floor wall above 1st floor hall. Need help with angled roof and 2nd floor exterior wall closed in. This is a remodel. need stair open to 2nd floor. there is a car lift in garage that has 142" clg ht clearance needed. Help would be appreciated. thanks, McMartin.zip Link to comment Share on other sites More sharing options...
ShaneK Posted August 30, 2016 Share Posted August 30, 2016 Fixed stairway, 2nd story wall, lowered garage floor 34", added car lift, put roof saddle between roofs. Edited : garage ceiling h. was not correct. McMartin 2016 mine.zip Link to comment Share on other sites More sharing options...
Designer100 Posted August 31, 2016 Author Share Posted August 31, 2016 Shane, you did great straighting out roof issue above hallway etc. but the ceiling in garage is only 9' ht (not 11' like you made it) everywhere, except above the custom car lift that I had designed stardard size to carry car up certain height ceiling just below the roof rafters. and another car parks below it.? Link to comment Share on other sites More sharing options...
ShaneK Posted August 31, 2016 Share Posted August 31, 2016 Raising garage height at car lift only will still result in same 2nd floor height and create framing issue that will require bearing support either with beams or walls. Sorry I deleted your custom car lift, . Tell me what you want and I will fix it. Link to comment Share on other sites More sharing options...
