EdLite Posted August 6, 2016 Share Posted August 6, 2016 The spec "Floor to Top" is this measured from the top of the subfloor to the top of the window frame; or from the top of the finished floor? It seems to be from top of subfloor. Also for example with a Full Camera view, when you set the camera height, is this height measured from the subfloor, or from the top of the finished floor? Link to comment Share on other sites More sharing options...
chief58 Posted August 6, 2016 Share Posted August 6, 2016 I do it from the subfloor to bottom of header on a 8' wall floor to top height is set to 83 3/8" which would represent the bottom of my header for the r.o. Link to comment Share on other sites More sharing options...
Solution justmejerry Posted August 6, 2016 Solution Share Posted August 6, 2016 Ed for windows you have three choices - absolute relative to 0' - 0", from floor(sub-floor) or from finished floor. Don't forget you will have your rough opening(whatever default you set) as well for header height. Basically most things are from floor height which is usually 0 for things that are measured to like camera...not sure if it would measure from terrain as some thing on outside can have that behaviour. Link to comment Share on other sites More sharing options...
EdLite Posted August 6, 2016 Author Share Posted August 6, 2016 thanks @justmejerry Link to comment Share on other sites More sharing options...
