Deleting invisible walls
chiefdwcox
I have several places where invisible walls seem to have generated themselves, and they refuse to be deleted.  They look like a dashed line on the plan, and affect the ability to generate other wall types.  For example if I try to draw a wall through the invisible wall, it will only draw a wall on one side or the other.  I select this hash tag line, open it, and it indicates it is an invisible line, but it won't let me delete it.  Any suggestions?  Thanks.
They are auto generated walls that connect rooms inside other rooms.
You can turn off this behaviour at Defaults...General Wall Defaults...Connect Island Rooms (Alt+Q).
You may have room definition problems in certain situations with this setting toggled off.
