How can I make this exposed wall exterior?
RyanDe
I'm trying to have two different pitched roofs and I finally got it to work but I have this issue of a wall gap that isn't exterior wall. Is there some box I need to check or something to fix that?
No, you toggle up to the attic level and then manually draw your missing wall using the reference display to help you draw it in the right location.
Hmm, I'll have to try that, thanks.  :-) It appears (sorry, not looking at it now) that with my pitch the way it is I'm also seeing a part of the second story and not just the attic. Would adding the attic wall fix this [if it's true] ?
Funny you responded, I just got done watching your videos on roofs. :-) Great stuff, keep it up.
