davidlgoss Posted July 15, 2016 Share Posted July 15, 2016 is there somewhere that you can change the wall height for entire floor, i have tried room by room which worked on my second floor , but seems to be locked on the first floor, thanks Dave Link to comment Share on other sites More sharing options...
dshall Posted July 15, 2016 Share Posted July 15, 2016 Raise second floor Link to comment Share on other sites More sharing options...
DavidJames Posted July 15, 2016 Share Posted July 15, 2016 If you want to raise you're entire first floor, go to your second floor and then go to your default floor heights in the default settings dbx (edit>default settings>floor). In that section, "ceiling below" will be your first floor ceiling height. Adjusting that height will effectively adjust the entire first floor ceiling height. Link to comment Share on other sites More sharing options...
davidlgoss Posted July 15, 2016 Author Share Posted July 15, 2016 thank you , all Link to comment Share on other sites More sharing options...
