Geyatautsilvsgi Posted June 22, 2016 Share Posted June 22, 2016 I need some assistance ASAP! I have been working on a plan for a couple of weeks now and out of the blue...last night my dimensions just went haywire. What I mean by that is that I am unable to dimension the center of any opening whether it be a door or window etc. I have spent an hour looking here for some suggestions as well as the knowledge bank on the chief site and no luck. So if any of you gentlemen have an idea or a suggestion I am all ears. Thanks. Link to comment Share on other sites More sharing options...
MarkMc Posted June 22, 2016 Share Posted June 22, 2016 For whichever dimension default you are using-under locate objects. It may be that was changed, or the annoset was changed and uses a different set of dimension defaults. Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted June 23, 2016 Author Share Posted June 23, 2016 Well, I at first I did not mess with my dimension settings when it happened. It was only AFTER l noticed that things were not working that I began to try different combinations. Thank you for your suggestion. I appreciate it. Link to comment Share on other sites More sharing options...
