2d fill eyedropper wierdness
lizdion
When changing fill color on a shape or 2d symbol, using the eyedropper in the color select dbx is giving me strange results. Moving the eyedropper around the screen does not pick up color under it. Sometimes it is only black or gray no matter what color I am over. Can work around fairly easily but this seems line a bug unless there is a setting I can't find.
It worked to select fill color from another object in plan in X7. Not sure if this started with X8 or more recently. Anyone else experienced this?
Liz
Thanks for the response, Michael.
Looks like it may be an issue with my computer. I'm working on a monitor attached to laptop. When I drag the dbx to the laptop screen, the eyedropper works. It used to work on the monitor so maybe it's just getting old and quirky. Seems to work fine otherwise.
