GLOBE-Res Posted March 24, 2016 Share Posted March 24, 2016 I'm using version 9.5. I'm trying to use a scanned jpeg for a floor plan by scaling the jpeg ( there are known dimensions ) and then rotating the jpeg. For some reason the jpeg won't rotate other than 90 degrees. Is there any thing I can do to get this to rotate something other than 90? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Not sure...works for me. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 Mike are you using v9.5? Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 I just dropped in another jpeg and it will only rotate 90 degrees? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 No. Sorry. Just wanted to get the ball rolling by ruling out issues with current versions. Must be a some sort of limitation in older versions? Have you tried holding down Control while rotating? Or do you have Transform/Replicate in 9.5? Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 I do have rotate & replicate. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 I just tried to Replicate, 0 copy, rotate angle 45 and it still rotated at 90 Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 Holding in the Control doesn't work either. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Maybe rotate it in a photo editor or Microsoft paint and then import that rotated image Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 I guess but I thought that Chief would rotate a jpeg. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Oh it does. I guess it just didn't 10 years ago. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 24, 2016 Author Share Posted March 24, 2016 Guess not. I used Photoshop to rotate and imported it that way. Paint only gives you 90 degree rotation. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2016 Share Posted March 24, 2016 Out of curiosity, would using edit area or group selecting make any difference? Link to comment Share on other sites More sharing options...
digitecht Posted March 25, 2016 Share Posted March 25, 2016 The 'Transfore>replicate>rotate' should work with any angle you specify. Don't know why you are having problem. By default, it will rotate at 7.5 degree increments (or 15) Must be plan specific. Post the plan. Francis. Link to comment Share on other sites More sharing options...
