Arch ext entry wall
Chief16Designer
You will need to clean the entire area up and get rid of the broken walls. This might help - I didn't do the entire archway but you can see where this leads as you can turn off the casing etc. Basically you were trying to shape the walls into an arch, but if you use a doorway it will be clean and easy to control.
