Connecting Leader Line Text to Objects
Joe_Carrick
When using a macro in Leader Line Text it is sometimes difficult to connect to the correct object.  Here's a little trick:
Select the Object and move it to the "Front Group" & also "Move to Front of Group".  The Leader Line will then connect to that object instead of another object at the same location.  In the case of Closed Polylines with a Fill the arrowhead can be inside the Polyline.
If the Polyline Fill is hiding something that you want to show - such as the walls under a Stairs, etc just make the Fill 25% transparent.
