Stairs - Max. Contraction
Jay_on_Cape
Hello All,
I know this has going on for quite a few versions but has the maximum contraction setting been fixed so it only jumps the set amount? I have in this picture winders checked with maximum contraction set to 4" so it will only jump to inside of the wall not across the hall. Is there a trick to get this correct short of getting rid of wall on left or doing stairs with cad blocks?
Thanks.
I never had this happen til X8. Now I can't use this feature any longer or every time I do, it looks like that. Need to send in a bug report. I will as soon as I get a chance as well.
Joey,
This is actually X7 and I've had this happen for way more than 1/2 dozen versions. I was just wondering if there is a cheat method short of cad lines like I used to use.
