False Shed Dormer
skirby19
I tried that, but it gave me an error saying...
Dormer roof does not meet base roof, probably near the top. You need to move the dormer down the roof or lower its height.
and then says cannot build walls for this dormer here because existing walls are in the way. It need to be moved to another position.
The problem is most likely in your roof design in relation to what dormer you want to see.  I can fit a auto-dormer in, but you have to enter parameters that work....although, the roof space is a bit tight in that area to make it work.
