djkitchens Posted February 17, 2016 Share Posted February 17, 2016 When I click on an opening or window, my current dimensions go to the outside of the wall. *See attachment* How do I change the default to go to the inside of the wall? Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted February 17, 2016 Solution Share Posted February 17, 2016 Your attached images are so small as to communicate nothing useful. Whatever changes are possible (other than manually) will be possible only in "Edit - Default Settings - Dimensions - Locate Objects". DJP Link to comment Share on other sites More sharing options...
djkitchens Posted February 17, 2016 Author Share Posted February 17, 2016 I have resolved the issue. Thank you. Link to comment Share on other sites More sharing options...
