Windows Above The Plate
mkennedy2000
I don't have this problem in X7. In X6 you can either:
1. Put the upper window in the attic wall; however, you won't be able to mull the upper and lower windows.
2. Put the upper window in the lower wall, then use the Transform/Replicate Object tool to position the upper window in the Z Delta (dragging the window results in the bumping behavior you are experiencing).
