Joe_Carrick Posted February 8, 2016 Share Posted February 8, 2016 There is a discrepancy between the Stair Height (Floor to Floor) vs the 2nd Floor Elevation. Basically, the Stair Height is 1/2" more than distance from the 1st Floor to the 2nd Floor. My Floor Finish in the dbx is the same for each floor (1/2" thick) I've reported it to support and sent them a sample plan. Is anyone else having this problem? If so, please report it to support (attn: Kirk Clemmons) Dermot has also confirmed that this is a Bug. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 9, 2016 Author Share Posted March 9, 2016 This problem only occurs when the lower floor is a slab. In that case the finish floor thickness of the lower floor is not being taken into account. This results in the riser height being reported incorrectly. I was hoping it would be fixed in the latest X8 update - but it wasn't. PLEASE move this up to the top of the list. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 9, 2016 Author Share Posted March 9, 2016 Here's a pic showing the problem. The First Floor is a Slab at Elevation 0 and has a 1/2" finish thickness. The Second Floor is at Elevation 109.375" and also has a 1/2" finish thickness. The text showing the Stair information is the result of a macro that uses the stair attributes. It should show the riser height as 7 13/16" and the total height of the stair as 9'-1 3/8". IOW: 14 R.@ 7 13/16" = 9'-1 3/8" The 1/2" discrepancy is the thickness of the first floor thickness. Note that if the first floor is framed construction instead of a slab the riser height is reported correctly in bot the stair dbx and in the attributes. Link to comment Share on other sites More sharing options...
