Sign in to follow this
WILL_in_PGH
Default Fill Pattern
Set the Default Fill Pattern to what I want?
It appears that the default fill pattern is angled line.
I want to be able to change the default per the layer set I'm in.
For instance, when I do marketing plans I go back and put a Solid Hatch in on walls.
I'd like to be able to set a default for a Layer set where I can show Existing in one color and New in another color.
The fill of your walls is controlled by the Wall Type (not on a Layer Set basis), but you could maybe add a Wall Hatch and turn off the display of Walls, Hatching (or move it to a different layer) on a Layer Set basis.
Chief usually handles existing/new a bit differently than you're trying to do though. Maybe check out this article?
http://www.chiefarchitect.com/support/article/KB-02208/showing-the-as-built-in-a-remodel-plan.html
    27628
    Fishios
    Fishios
