Change Electrical Label Fills
LewisConDev
Does anyone know how to affect the background (fill) color of labels on the "Electrical, Labels" layer? It becomes difficult to properly place these labels when they start overlapping other symbols, and then hiding what's behind them.
In the attachment, you'll see two examples of GFCI-protected outlets. The one on the right is the standard GFCI library object. The one on the left is a quadplex outlet that is GFCI-protected, but because there is not a separate symbol for this, I used the object label to specify it. The problem is that the label is now covering the symbol (if I leave it here). I run into many situations where I have tight space and the label fill starts getting in the way.
