Roof Help - Attic Wall Not Extending Properly?
dvanelli
Hello,
I do not know if this is the correct place to ask this question, but, I cannot figure out how to correct this and have investigated all the wall & room settings I can.
I am modelling a small sunroom addition to a house. Pictures attached. It appears that one outside wall works when the roof pane is manually added / the other side does not fill in the "attic" space.
Pictures attached. It seems nothing I do changes this?
Best,
-Donnie
Post your plan. You will need to save and  close the file in CA before uploading. Could be several things. Easy fix is to build an attic wall. Draw a wall above that wall and hit the check box for Attic Wall. Do you want to the brick to continue. Do you want a flat ceiling in that little shed room? If no, then uncheck "Ceiling" for that room and make those walls balloon.
