woodcraftdesign Posted December 1, 2015 Share Posted December 1, 2015 why does this keep creating a gable on the end of this front porch shed roof? I will attach the plan files, thanks for the heads up. not quite up to speed on the forum etiquette . trouble uploading.... used advanced uploader...No file was selected for upload has anyone seen this note before? I also tried another version of the same file, slightly smaller. i got "This upload failed" I will research this error and update the question when I get this figured out. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 1, 2015 Share Posted December 1, 2015 For an accurate answer you should probably attach the plan. Link to comment Share on other sites More sharing options...
woodcraftdesign Posted December 1, 2015 Author Share Posted December 1, 2015 I got this little gable to operate right when I changed the invisible porch wall to a standard 2x4 exterior wall which runs continuos through the corner Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted December 1, 2015 Solution Share Posted December 1, 2015 It looks to me like perhaps your walls aren't aligned properly. Link to comment Share on other sites More sharing options...
woodcraftdesign Posted December 1, 2015 Author Share Posted December 1, 2015 that worked.... keep it simple, thanks. also FYI a cant replicate the issue now unless I offset the porch wall at east 2" out of alignment. Link to comment Share on other sites More sharing options...
