ChiefLBC Posted November 24, 2015 Share Posted November 24, 2015 I'm wondering how to delete shadows from a ray trace in a "Perspective Floor Overview" floor plan. I'm trying to use a floor plan for a color rendering presentation but the shadows are overwhelming on the drawing. Thanks! Also can chief architect not do a straight on shot from above similar to floor plan view but show the colors of a 3-D ray trace drawing? (like the ones you see in brochures all the time??? Link to comment Share on other sites More sharing options...
HamlinBC Posted November 24, 2015 Share Posted November 24, 2015 Just simply do a 3D overview, and do a Final View (without shadows). If you want shadows just do a Final View w/Shadows. See attached... Link to comment Share on other sites More sharing options...
ChiefLBC Posted November 24, 2015 Author Share Posted November 24, 2015 Thanks for the reply. How is a ray trace done on this 3D overview (without shadows) Is your pics a ray trace or just the 3D Overview? Link to comment Share on other sites More sharing options...
HamlinBC Posted November 24, 2015 Share Posted November 24, 2015 If you want straight on do the "Orthographic Floor Overview", and then change the render style to "Standard"... Again...see attached. Link to comment Share on other sites More sharing options...
HamlinBC Posted November 24, 2015 Share Posted November 24, 2015 My pictures are just 3D Perspective/Orthographic Floor Overviews...probably not much gained by going with an actual raytrace. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 24, 2015 Share Posted November 24, 2015 Ray Traces are by nature "Light Source Dependent" so you have to select the type of lighting. In this case, you would not want bright sunlight since it would create strong shadows. I would probably select "Overcast" and then after the RT was done adjust the Image Properties. For the "Overhead View" chose 3D > View Direction > Top Link to comment Share on other sites More sharing options...
ChiefLBC Posted November 24, 2015 Author Share Posted November 24, 2015 thanks fellas appreciate it! Link to comment Share on other sites More sharing options...
HamlinBC Posted November 24, 2015 Share Posted November 24, 2015 Ok, after looking at it a little more...here's what I came up with. Make sure you place a Sun (draw a north arrow and then draw a sun arrow. These can both be found under the plain 'ol CAD>Lines menu). Then if you open up the Sun and go to "Lighting Data" on the left, under that you'll see "Cast Shadows". Uncheck that, and do your 3D view again. From there you can run your raytrace. See attached results...I didn't setup my materials or raytrace very well, but you get the idea. Link to comment Share on other sites More sharing options...
ChiefLBC Posted November 24, 2015 Author Share Posted November 24, 2015 I just saw that myself Jonathan...works great now except it doesn't show windows and doors well in the "Orthographic Floor overview because your looking at it staright on instead of a slight angle like the "Perspective Floor Overview" But its really starting to look good now. Link to comment Share on other sites More sharing options...
ChiefLBC Posted November 24, 2015 Author Share Posted November 24, 2015 The one on the left is "Perscriptive Floor Overview" and the one on the right is "Orthographic Floor Overview" Link to comment Share on other sites More sharing options...
HamlinBC Posted November 24, 2015 Share Posted November 24, 2015 Yeah, I agree. The perspective looks much better. Link to comment Share on other sites More sharing options...
