sdupes12 Posted November 24, 2015 Share Posted November 24, 2015 Hi guys, I am trying to build a room with 2 knee walls on the side and have the roof plane connect to the top of the garage. Whenever I try to use the knee wall feature in x7 this error message comes up. What does it mean? Please Help! Home plan_2(B).planFetching info... Link to comment Share on other sites More sharing options...
rlackore Posted November 24, 2015 Share Posted November 24, 2015 Where are you trying to draw the walls? Which roof plane? Knee walls are explained on page 290 of the Reference Manual - this explains the error message better than I can. Link to comment Share on other sites More sharing options...
chuck_g Posted November 25, 2015 Share Posted November 25, 2015 If you select the two walls that two end walls that connect to the knee walls it will bring you closer to what you need. Your going to have go manual with the roof design eventually. Modified plan attached. Home plan_2(B).zipFetching info... Link to comment Share on other sites More sharing options...
