ED-209 Posted November 19, 2015 Share Posted November 19, 2015 Hi, I'm trying to get some of the flower images to sit on the roof, like I can do with symbols. So; is there anyway, apart from changing the "height from floor" on each item, that I can either: 1) Get the image/object (look up Papaver Oriental in the core catalogue) to "sit on roof", such as a symbol can or, 2) Convert the flower image to a symbol, so I can then change its setting to "sits on roof" Thanks everybody, Ed Link to comment Share on other sites More sharing options...
rlackore Posted November 19, 2015 Share Posted November 19, 2015 You can make a Symbol by creating a Face and assigning it a Material that uses the plant image as the Texture - BUT it's a pointless exercise because the Symbol won't behave like the plant Image - in other words it won't automatically turn to face the camera. Chief hasn't given us the ability to assign that kind of behavior to a Symbol - only to an Image. Link to comment Share on other sites More sharing options...
ED-209 Posted November 19, 2015 Author Share Posted November 19, 2015 Fair enough, I only ask because a lot of the "face me" items on 3d warehouse don't actually work. I'm doing a couple of brochures at home, so I have to manually turn each foxglove to face the camera. Link to comment Share on other sites More sharing options...
rlackore Posted November 19, 2015 Share Posted November 19, 2015 You can extract the image used in the SketchUp file and import into Chief using Build>Image>Create Image. Then it will have the proper "face me" behavior. EDIT: Or better yet, use Terrain>Plant>Create Plant Image. Then you can add all sorts of plant data if you want. Link to comment Share on other sites More sharing options...
