bomcnabb Posted November 4, 2015 Share Posted November 4, 2015 Not sure how to fix this. It appears that the window is incorrect in the wall. Tried a few adjustments. Not sure how to get it set correctly. I can send the file if needed. Attached is picture Matt and Jordan.plan Link to comment Share on other sites More sharing options...
Greg_NY61 Posted November 4, 2015 Share Posted November 4, 2015 Here you go its all fixed. Go to your wall DBX properties and remove #2 wall layer as indicated in the picture. That what caused the window issue. Matt and Jordan_fix.plan Link to comment Share on other sites More sharing options...
