site plan
Member Statistics
Similar Content
By Ange822
Good morning,
I am helping a college who is having issues exporting a Chief File into a CAD . dwg file.
The issue is, she had imported a .jpeg of a clients survey to draw over to create a site plan.
Now trying to export the file to CAD, it will not export the .jpeg with it (that we sized / rotated into place).
The other option would be just to import the .jpeg into CAD and re-size / rotate to fit, but wasn't sure if their was an easier way.
See the files attached.
thanks in advance for the help!
McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.plan McMillan -custom-VER.4- SITE - 08.17.21 ENTIRE LOT.dwg
By steve_mcdowell
Looking for design partner for upcoming projects. My previous designer used Chief and he is too busy to take on additional work. Ideally looking for someone who may have building experience in addition to being a designer. Looking for someone who can deliver preliminary floor plans and elevations to facilitate proof of concept, someone who can design to specific standards for ARC review and submission standards. The designer will need to understand page naming conventions and all related requirements for the city of Bend Oregon for streamlined permit submission. Structural drafting and coordination with structural engineers.
See attached files as example of the type of drawings needed
A0.01 COVER SHEET.pdf
A0.02 PLAN NOTES.pdf
A1.01 SITE PLAN.pdf
A1.02 MAIN FLOOR PLAN.pdf
A1.03 LOWER FLOOR PLAN.pdf
A1.04 FOUNDATION AND LOWER FLOOR FRAMING.pdf
A1.05 LOWER ROOF AND UPPER FLOOR FRAMING.pdf
A1.06 UPPER ROOF FRAMING.pdf
A2.01 EXTERIOR ELEVATIONS.pdf
A2.02 EXTERIOR ELEVATIONS.pdf
A3.01 BUILDING SECTIONS.pdf
By jcaffee
I'm having an issue in X10 using the Edit Area (All Floors) tool to rotate my site plan to a know reference line using the Make Parallel tool. I select the terrain perimeter (on the line segment I wish to align with the reference line), then select Edit Area (All Floors). I then select the Make Parallel tool, set to rotate the entire polyline, and select my reference line. Everything rotates, but a line segment of the terrain that I did not select gets the perpendicular treatment.
I know I've done this before, but for the life of me, I can't figure out what user error is involved.
See attached. (Notes in plan)
Lot Trouble.zip
By SNestor
How do you dimension the distance between the property line and the setback line? I can't seem to get any of the dimension styles to "click" onto these lines. Do I have to draw a perpendicular line and add arrows to the line...and show the dimension?
Surely I'm missing something simple...
Thanks
