Merano-Design Posted June 1, 2015 Share Posted June 1, 2015 I'm using X7 and can't find an answer in the help search to this question. I am wanting to connect two stair lights to two switches that are on different floors. The first switch and lights are placed, and connected on the second floor layer and the second switch is on the first floor layer. It is this first floor switch I'm wanting to connect to, to make it a two way. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 1, 2015 Share Posted June 1, 2015 I usually use a CAD ARC with an arrow on it pointing upstairs or downstairs with the text that says "to light or switch above" as the case may be per instance. Not elegant but workable since no Chief Architect can do what you expect or want. You can use a three-way switch from the Library Browser when that is your need since the automatic function change will not do it for you, you do it manually yourself. DJP Link to comment Share on other sites More sharing options...
