Designer1 Posted May 25, 2015 Share Posted May 25, 2015 Does anyone know how to get the 3d views to not be able to see inside the windows, make them opaque or some option? Reason I want to do this is if I do a sketch of it, it tends to show too much detail in the windows because its showing the inside of the house and makes the end result look indistinguishable because its too busy. Any ideas? Thanks! Chad Link to comment Share on other sites More sharing options...
Designers_Ink Posted May 25, 2015 Share Posted May 25, 2015 You can just use the material painter to paint the windows white or whatever color you chose. You can also go into the material definition and change the transparency to 0%. In a vector, there is a setting in the Camera -> 3D Views settings to make the glass opaque. Link to comment Share on other sites More sharing options...
Designer1 Posted May 25, 2015 Author Share Posted May 25, 2015 Great, thanks for that information. Yes, I saw that choice for vector views, I wish they also had that choice for 3d views. I will try using those options you gave. Thanks for the reply! Link to comment Share on other sites More sharing options...
