mark2457 Posted May 21, 2015 Share Posted May 21, 2015 Hi All Looking for a material like LP SmartSide http://www.menards.com/main/building-materials/siding/ppg-prefinished-siding/ppg-prefinished-engineered-wood/lp-smartside-3-8-x-4-x-9-premium-prefinished-8-oc-groove-engineered-t/p-2238339.htm Anyone know if there's anything similar available? Thanks mark Link to comment Share on other sites More sharing options...
chief58 Posted May 21, 2015 Share Posted May 21, 2015 see if this will work for you it is from 3d warehouse https://3dwarehouse.sketchup.com/model.html?id=9aa6e1c4c758f9bee6bd89d9bbf9e646 Link to comment Share on other sites More sharing options...
chief58 Posted May 21, 2015 Share Posted May 21, 2015 I also made these 2 walls in Chief using beadboard pattern and adjusting to 8" wide and stretch to fit this might work also Link to comment Share on other sites More sharing options...
chief58 Posted May 21, 2015 Share Posted May 21, 2015 here are the 2 walls that I made if you can use them or adjust them from what I am sending you walls.zip Link to comment Share on other sites More sharing options...
mark2457 Posted May 21, 2015 Author Share Posted May 21, 2015 Thanks Ray. I think that'll work Link to comment Share on other sites More sharing options...
