mark2457 Posted May 17, 2015 Share Posted May 17, 2015 Hi Guys Designing garage and need 24 OC studs Default was set to 16 OC. I've changed default and can't for the life of me get it to rebuild. In Build Framing Dialog I have everything checked (see attached) What do I need to do to have it change to 24 OC Thanks Mark Link to comment Share on other sites More sharing options...
Solution mark2457 Posted May 17, 2015 Author Solution Share Posted May 17, 2015 Figured it out. Deleted framing and rebuilt and entered 24' OC and it worked Link to comment Share on other sites More sharing options...
AndyGump Posted May 18, 2015 Share Posted May 18, 2015 And you marked your own post as the "best answer", wonderful. Andy. 1 Link to comment Share on other sites More sharing options...
