Kmac7476 Posted yesterday at 06:18 PM Share Posted yesterday at 06:18 PM When I create a Dimension string then move it away from the building, it does not extend the Extension Lines. I have to lengthen them manually which obviously takes a lot of time in a house layout. I know Chief is supposed to extend the Extension Lines as you drag it so I obviously did something wrong at some point. I need to get that turned back on. Link to comment Share on other sites More sharing options...
DBCooper Posted 21 hours ago Share Posted 21 hours ago Look at the "extensions" panel in your dimension defaults dialog. My guess is that you are set to "length towards marked object" instead of "fixed gap from marked object": Link to comment Share on other sites More sharing options...
