Sassoondesign Posted August 14 Share Posted August 14 Hi, I am currently using Chief vesion X12 that I purchased and used for the last 8 years. Is there a way to import 3d Sketchup warehouse objects into the older version? It says "this skp version was created in incompatible software. Unable to import". I've tried downloading each of the available file options. I also wanted to know if there is a way to adjust default settings to that when I manually draw a 3d molding line (such as a chair rail on one wall), it appears as the rounded edge molding I prefer, rather than the usual square. I can't find the setting in defaults. Thank you Link to comment Share on other sites More sharing options...
para-CAD Posted August 14 Share Posted August 14 This is coming straight from memory, so it may be incorrect, but I remember having to export to a .stl file and then import that into Chief back then. Link to comment Share on other sites More sharing options...
