As Built App Metric Defaults
mthd97
Hi all, is there a way to set the wall thickness default to say 110mm so that every time I create a room it has these defaults ? I know I can create a room edit the wall thickness and drag a copy.
Seems like that this app would need to have a metric template version to be useful where metric units is the convention ?
I created a room and edited the walls to 110mm thick and made the room size 4800mm x 4800mm by editing the dimensions. I then click on the dimensions and I get 4800.001mm when I have set the default units to mm with zero decimal places ???
I think this is the case because the app is set to imperial units as its base. It would be good to have a metric template base version for regions that use metric units.
Thank you in advance.
Edited by mthd97
I haven't found any global default adjustment location past the few basic ones. I may be incorrect, but I suspect that the program can't get too bulky with options and still function on the small horse powered devices. I wouldn't be surprised if the default wall thickness stays at the one pre programmed option (114mm) , just like the only door option is a hinged door.
As for the triple decimal showing up, I did a quick room scan and found that once I manually adjusted the wall thickness and moved the walls to 4800mm, I had all but one wall measurement record the unwanted .001 mm add on, even though the default was set to zero decimal positions.
I also placed a room and set walls to 110mm and room size to 4800mm and every dimension was correct with zero decimal positions... until I pushed one wall to 5500mm and back again to 4800mm, this prompted the .001 to show up again on all of the measurements.
I'd say this is a bug and suggest that you let Chief know about it.
I think the app was designed to work in imperial units initially and it is basically an upgrade from the older Home app we used to have. Probably just needs a metric one for lands that use those units maybe ?
I personally would prefer to use home designer pro on a windows tablet pc for an as built survey. For regular home owners this app would help them to take an initial scan for us to start with anyway.
This possibly could be the case.
Even though we are a Commonwealth country, only government jobs use metric that I know of here. I agree with having a separate metric template, especially if the common wall thickness is consistent between metric using countries - changing every wall ever scanned would be a royal pain for sure!
