Chrisdutch89 Posted 22 hours ago Share Posted 22 hours ago (edited) I was working on a project and my client wanted to change the front elevation from Board and Batten to Stucco. I used the default settings to do the change, but the elevation is not reflecting the change of material. I could use some help with this. Elevation.pdf Edited 21 hours ago by Chrisdutch89 Link to comment Share on other sites More sharing options...
ChiefTylerL Posted 22 hours ago Share Posted 22 hours ago @Chrisdutch89, it sounds like you may have used the Material Painter at some point to change material, which will override the material you have set in your Wall Type. You likely need to set your wall back to using its Default Material, which will then use the material that is set in your Wall Type. Here is an article that will walk you through the steps: https://www.chiefarchitect.com/support/article/KB-03182/restoring-default-materials.html 1 Link to comment Share on other sites More sharing options...
