Chrisdutch89 Posted May 19 Share Posted May 19 (edited) I was working on a project and my client wanted to change the front elevation from Board and Batten to Stucco. I used the default settings to do the change, but the elevation is not reflecting the change of material. I could use some help with this. Elevation.pdf Edited May 19 by Chrisdutch89 Link to comment Share on other sites More sharing options...
ChiefTylerL Posted May 19 Share Posted May 19 @Chrisdutch89, it sounds like you may have used the Material Painter at some point to change material, which will override the material you have set in your Wall Type. You likely need to set your wall back to using its Default Material, which will then use the material that is set in your Wall Type. Here is an article that will walk you through the steps: https://www.chiefarchitect.com/support/article/KB-03182/restoring-default-materials.html 1 Link to comment Share on other sites More sharing options...
