Need help converting a current Chief Architect file
MNKnute
need the file saved specifically so it is editable in Home Designer 2019, not just viewable.
What I need done:
  • Open current .caproj / newer Chief file
  • Save/open in Chief Architect X10
  • Enable “Allow Editing in Home Designer”
  • Save as .plan
  • Confirm it opens in Home Designer Interiors 2019
I’m happy to tip $25 for a quick turnaround.
Please reply or DM if you still have Chief X10 installed and can help with a one-time file conversion.
Thanks!
Sorry to be the bearer of bad news but any Chief Architect files saved in any version after X10 can't be opened and then saved in X10.  Chief has never been backwards compatible (and from what I have heard it probably never will be).
The best you could probably get is to export a dwg or pdf that you could then trace over in HD 2019.
Edited by DBCooper
