CoastlineFl Posted March 31 Share Posted March 31 I am trying to draw a deck over a porch and I keep getting the error message "Deck is over a non deck room. Framing may not be correct." The porch below is concrete and I'm not sure how to call it a deck but not get all the deck framing.... Seems like it would be no problem to build a deck over a porch. I noticed in the Bachlelor model they just made a slab so it appears the deck is over the ground. Is there any way to make the deck over a "non-deck" room? or maybe make a concrete deck? Link to comment Share on other sites More sharing options...
CarrieS Posted March 31 Share Posted March 31 Hi, The "Deck is over a non deck room. Framing may not be correct." message doesn't mean that anything is wrong exactly. It is just a notification because it is in a scenario that might need custom changes. If you've inspected and you're ok with the model, it is perfectly ok to ignore that message. Hope this helps! Carrie Link to comment Share on other sites More sharing options...
