X6 Replace from Library Tool Problem
Joe_Carrick
When I select a Door and then select the "Replace From Library" icon - only "Doorways" in the Library are available.  I want to replace the Door Symbol itself.
Obviously this should work since it works from within the Door dbx.  I don't know if it was this way in X5, but IAE it's a PITA.
Try using "Open Object" button > General > Library.. This will access all doors in the database.
Hope this helps.
-Aros
Yes, I know that works.  It's what I meant when I said it worked in the Door dbx (aka "Open Object" button > General > Library).  I'm just saying that it should work that way with the Replace from Library icon.
