TSutton Posted February 17 Share Posted February 17 I am using CA x17 on a Dell XPS with Nvidea 4080. I try and perform any task and CA, for lack of better terms, ignores it. I try and delete, it highlights and when I hit delete, it does not delete. I try adding a cad line, it shows it until I release the mouse key and then it disappears. Add sollid, nope, add or delete anything does not work. I restart software and computer, it works for about 10 or 15 commands, then it starts back up with these games. Any suggestions would be greatly appriciated. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 17 Share Posted February 17 (edited) you could check the CA log file. I think you can see where it is located under preferences. It almost sounds like you are being starved for resources if it works for awhile. Other far out possibilities:virus scanning constantly running against the CA data directory where CA is constantly writing files, but that is a way out there guess. You could also disable the Nvidea card to see if that is related but better question is when did it start to do this and what happened just before that Edited February 17 by SHCanada2 Link to comment Share on other sites More sharing options...
