pktraylor Posted April 16, 2015 Share Posted April 16, 2015 It has been years since I had to flip a house plan. The last time I did resulted in problems. Is there a simple way to flip a house and have everything move? Thanks much, Paul Link to comment Share on other sites More sharing options...
glennw Posted April 16, 2015 Share Posted April 16, 2015 Paul, There are a couple of ways that should work OK: Reflect About Object (on the Edit toolbar - after selecting all the objects) Note that you can use any of the Edit Area tools for selection, and then use Reflect About Object. Tools...Reverse Plan (for a left to right flip) Transform/Replicate Object - Reflect - with or without Edit Area. Stay well away from Rotate Plan View. Link to comment Share on other sites More sharing options...
