PitMan71 Posted 5 hours ago Share Posted 5 hours ago I recently upgraded to X17 from X16. I noticed that my style pallet for my windows that have the brick lintel and sill configured no longer work. It has reverted the style to default so I attempted to rebuild. I got it all set up again but the Style Palete will not retain either profile that I set. I changes it back to default after I save it. Anyway, having the pallete is huge time saver when doing brick homes. Would like to nail down what's going on and fix it. Thanks Link to comment Share on other sites More sharing options...
Renerabbitt Posted 5 hours ago Share Posted 5 hours ago 15 minutes ago, PitMan71 said: Anyway, having the pallete is huge time saver when doing brick homes. Would like to nail down what's going on and fix it. change your window default, so that when you change to your brick sill, it isnt default. Link to comment Share on other sites More sharing options...
PitMan71 Posted 3 hours ago Author Share Posted 3 hours ago 1 hour ago, Renerabbitt said: change your window default, so that when you change to your brick sill, it isnt default. Thanks for the response, but I am not following. Thanks. Link to comment Share on other sites More sharing options...
Renerabbitt Posted 2 hours ago Share Posted 2 hours ago 28 minutes ago, PitMan71 said: Thanks for the response, but I am not following. Thanks. A style palette will only save as default if the setting you’re trying to store in the style palette is currently set as the active default. To make this work correctly: Change the sill on your window to something different. Set that window to default. Change the sill back to your brick option. Then save it to the style palette. This ensures the style palette recognizes the updated setting as the new default. 2 Link to comment Share on other sites More sharing options...
