PattyOD Posted December 14, 2025 Share Posted December 14, 2025 Hi there! I am trying to import a picture of a bourbon barrel head (circle) with a transparent background into Chief putting it on a 3D solid poly line 22" in diameter. I am selecting shrink to fit but when i spray it on the 22" polyline the barrel head is showing up more like 10" diameter and I cannot get it to fill the full ppolyline. Can you please provide some guidance on what I am doing incorrectly? Thanks much. Link to comment Share on other sites More sharing options...
DBCooper Posted December 14, 2025 Share Posted December 14, 2025 I assume you mean "stretch to fit" but basically it sounds like what you are doing should work. Could either be a problem with the image you are using, or a problem with the way you have setup the material, or maybe something else? You could try posting the image on the forum but it would probably be best to post the full plan (and include the image) if you want someone to dig into more. Link to comment Share on other sites More sharing options...
