Diconnected walls and missing layers in plan view
tbuck1db
Go to solution Solved by ChiefTylerL,
I imported this plan from a .DWG file and then used cad to walls to create the initial model. I can't figure out why each of the walls has a line at then end of it and is missing the siding layer. I've never seen it before and must have to do with the .DWG import and cad to walls function. Can anyone tell me how to fix those two items?TBA plan Rynowecer; Scheme 3.zip Using X17.
Edited by tbuck1db
  • Solution
Hello @tbuck1db, in the attached plan you have both the Walls, Main Layer Only and the Walls, Through Wall Lines layers enabled which are going to control how your walls are displayed.
To fix this:
1. Go to Tools> Layer Settings> Display Options
2. Find Walls, Main Layer Only and Walls, Through Wall Lines and turn these layers off
3. Click OK
This should display your walls like you're used to. I hope this helps!
