Renerabbitt Posted December 3 Share Posted December 3 Maybe @Eric_S? I have hundreds of missing textures. In past we were able to point to a search directory and it would find these textures by name. That method does not work any more. I could export my full library or a project and it would prompt me with missing textures and I could group select all and add a search directory and chief would find and load the missing textures as well as retroactively fix my user library. That entire wonderful function does not function any more. It never finds missing textures from a root folder that contains them all. To my knowledge the asset manager is about as useless as it comes for missing texture files. Having to do hundreds of textures one by one is not going to work for me, and merge duplicates has no option to merge a texture of the same name where one has the texture and the other is missing..big opportunity to fix a lot of problems for me. What other methods can I employ to efficiently recover my missing textures? Link to comment Share on other sites More sharing options...
Eric_S Posted December 3 Share Posted December 3 Hi Rene, sorry to hear you're having trouble with missing textures. We have some requests to improve the asset manager which are prioritized, but please report your own suggestions if you haven't done already. It could also help us to know how you are getting hundreds of missing textures. Are these all from when you started using X17? Link to comment Share on other sites More sharing options...
Renerabbitt Posted December 3 Author Share Posted December 3 1 minute ago, Eric_S said: Hi Rene, sorry to hear you're having trouble with missing textures. We have some requests to improve the asset manager which are prioritized, but please report your own suggestions if you haven't done already. It could also help us to know how you are getting hundreds of missing textures. Are these all from when you started using X17? I was in early beta of X17 and my machines specifically had a number of issues that carried over which caused migration issues unbeknownst to me. I did several hundred hours worth of updates to my library and came to find out I had to wipe chief from the registry and start a fresh install and import my library. The library at this point was already missing textures from the problems with migration and I was unwillingly to try and migrate my old catalogs as they didn't have all of the new work I had performed Link to comment Share on other sites More sharing options...
